Starting in reverse
Starting in reverse
Postby Teglease » Sun Aug 16, 2015 3:29 pm
Hi' I'm running a sil Gp 150cc engine with a 185cc barrel & 28mm Dellorto PHBH carb, everything was fine until it just started to start in reverse
:( :o :o how the hell do I stop it and make it start correctly ,,,,,, help I can't go to the IOW backwards
Teglease
Re: Starting in reverse
Postby MickYork » Sun Aug 16, 2015 3:42 pm
check your timing
.......or get some decent rear mirrors :)
Postby Teglease » Sun Aug 16, 2015 4:02 pm
Thanks, Mick forgot to add it's 12v electronic ignition
Teglease
Postby jonoy » Sun Aug 16, 2015 4:09 pm
Happened to a mate of mine years ago
Caused by Change in temperature
jonoy
Postby Teglease » Sun Aug 16, 2015 4:14 pm
Hi' jonoy how so it changes temp all the time when running ?????
Teglease
Postby CHRIS in MARGATE » Sun Aug 16, 2015 4:35 pm
Timing is wildly out.
Postby grandpa » Sun Aug 16, 2015 5:11 pm
Hi Teglease,
Timing too far advanced.The 1960's Messerschmitt buble car had two sets of points to advance timing so that it could reverse.You had to stop press a button or something and it then used the second advanced points to reverse engine.Fortunately Lambrettas were never fitted with this feature :lol:
Grandpa
grandpa
Postby MickYork » Sun Aug 16, 2015 5:24 pm
The flywheel may have sheared the woodruff key and have slipped.....in effect causing slipped timing.
Postby Teglease » Sun Aug 16, 2015 6:13 pm
Thanks guy's Timing it is then :D :D :D
Teglease
Users browsing this forum: Bing [Bot] and 6 guests
