by 59 lammy boy » Sun Jul 06, 2014 10:19 pm
Scooter starts okay on choke and runs okay. Push the choke in the engine has warned up and it just stops. Won't run without choke
Help please
59 lammy boy on Tue Jul 08, 2014 3:09 pm, edited 2 times in total.
59 lammy boy
by Toddy » Mon Jul 07, 2014 6:27 am
Have you had the carb of and cleaned the jets ? sounds like a blockage from your short explanation
by paul213 » Mon Jul 07, 2014 3:52 pm
is it a std carb just had a similar problem on a jet turned out to be a blockage in the brass restricter next to the mouth of the carb (on the left as you look straight at it) that feeds air to the pilot circuit prodded it out with a piece of 1mm welding rod ,runs fine now
paul213
by Paulnobodyimportant » Mon Jul 07, 2014 4:24 pm
Out of the blue, that happened to me last Thursday on a 22mm dellorto. Suspected a dirty pilot jet and that's what the problem was.
So, cleaned pilot jet with a blast of carb cleaner. And for good luck, cleaned rest of carb jets and holes with spray carb cleaner. Runs OK now.
Paulnobodyimportant
by bigbthesoulman » Tue Jul 08, 2014 11:42 am
Carb problem,try a good clean up,if not could be starved of fuel ,ok with choke not without check flow from tap
bigbthesoulman
by 59 lammy boy » Tue Jul 08, 2014 3:08 pm
Thanks for all your advice
Now sorted. Just took carb off and got the air line to it. Perfect
59 lammy boy
