Ready cut Cylinder cowl for TS1
Postby soullad » Tue Feb 23, 2016 4:57 pm
Hi, Does anybody sell cylinder cowls ready cut for the TS1 barrel / reed block / oval exhaust etc
Cheers, Ian
soullad
Re: Ready cut Cylinder cowl for TS1
Postby a.lo » Tue Feb 23, 2016 5:50 pm
AF do them , i got a TS1 type to hopefully fit an Atomic reed valve better they also have a RB type. i do not know the difference probably a bit more cutaway which may or not have suited my need better.not fitted yet so unsure.
a.lo
Postby Wack » Tue Feb 23, 2016 6:49 pm
The AF ones are a lot thicker which should stop it splitting but when I fitted one the 3 bolt holes were miles out so had to weld them up resulting in having to use Allen screws in the 2 mag housing threads as no room for an 8 mm headed bolt. Seems to me the form was taken off the outside of a cowl resulting in it being larger.
Postby Dazts1 » Tue Feb 23, 2016 7:17 pm
Try Andy Francis. I don't think you'll find a better one off the shelf.
Postby soullad » Tue Feb 23, 2016 9:49 pm
Cheers fellas
soullad
Postby Toddy » Wed Feb 24, 2016 7:12 am
Dazts1 wrote:Try Andy Francis. I don't think you'll find a better one off the shelf.
+1
Postby a.lo » Wed Feb 24, 2016 1:09 pm
excuse me if i am wrong, but aren,t these the AF ones anyway?
a.lo
Postby Toddy » Wed Feb 24, 2016 1:15 pm
Dont think unless he has changed , Andy was doing these Before AF fetched theirs out mine has a thick wire/weld to stop splitting and was powder coated
Postby soullad » Wed Feb 24, 2016 5:12 pm
I have been reliably informed that these are not the same as the AF versions. I have ordered one so can pop a pic up if anyone wants when it arrives?
soullad
Postby Wack » Wed Feb 24, 2016 7:07 pm
Mine came from Andy Francis and I presumed they were the same as AF's. Either way it didn't fit and I also had to mod the fly cowl where it sits over the lower mag casting that holds the head cowl.
Postby Toddy » Wed Feb 24, 2016 7:22 pm
Wack wrote:Mine came from Andy Francis and I presumed they were the same as AF's. Either way it didn't fit and I also had to mod the fly cowl where it sits over the lower mag casting that holds the head cowl.
Strange that mine was spot on mine was on a ts
Postby Dazts1 » Wed Feb 24, 2016 11:04 pm
Andy has them modified. The man who modifies them has been doing them for a while. I don't think I've seen a better head cowl out there. They probably are AF ones but modified.
Postby Norrie Bodge » Thu Feb 25, 2016 3:42 pm
Just took mine to coaters without trying it?
Hope the F@@ker fits?
Norrie Bodge
Users browsing this forum: Bing [Bot] and 7 guests
