Running issues tv175
Re: Running issues tv175
Postby Kristof Lammy pie » Tue Mar 01, 2016 3:41 pm
Yeah I think your right Johnny. I've literally changed everything I can with regards to the fuelling so it has to be electrical.
The wiring has been a problem in the past by the looks of things as the lights are always on no matter where the ignition key is placed.
Electrics arent my strong point by any stretch.
Kris
Kristof Lammy pie
Postby grandpa » Tue Mar 01, 2016 3:44 pm
Checked the carb everything looked ok, noticed the fuel in the fuel pipe was bubbling with a big air gap. Switched it over to res,off and on no difference.
Hi Kris,
Do you have a kink in fuel pipe when sitting on machine.
Have you shone a bright light into the tank (LED torch) and looked inside especially where tap filter pokes through for any debris that might be clogging the filter.
As Adam Winstone suggests disconnect green wire to ignition switch especially as you have problems with the ign switch.You will have to stall the machine to stop engine.
grandpa
Any ideas anyone?
It's a sx200 Spanish motor with standard air filter and a 25mm phbl Dellorto.[/quote]
grandpa
Postby Kristof Lammy pie » Tue Mar 01, 2016 4:34 pm
It's a clean replacement tank and a new tap, I did think it could be the tube catching under the engine mount as soon as my fat arse was on the bike but it wasn't.
Will go through the electrics when I get a chance.
Kristof Lammy pie
Postby Kristof Lammy pie » Sun Mar 13, 2016 11:21 am
With a full day spare, I decided to start looking at the fault on the TV.
I've removed the CDI and noticed a loose earth wire not attached, could this be a problem?
So the wire to be removed is the top green wire is that correct?
Finally is the fuel hose too long to push fuel into the carb?
Kristof Lammy pie
Postby Jazzy b » Sun Mar 13, 2016 11:59 am
My mate had similar prob changed cdi sorted
Jazzy b
Postby CHRIS in MARGATE » Sun Mar 13, 2016 12:07 pm
Fuel pipe is fine. Gravity fed and fluids always find their level.
Postby Kristof Lammy pie » Sun Mar 13, 2016 12:13 pm
Cheers.
So I've done the 3 tests listed in the Stickys Book above.
First test. Result. . 5
Second test Result. 96.5
Third Test. result. 456
So I'm guessing all is fine there.
Kristof Lammy pie
Postby rossclark » Sun Mar 13, 2016 12:19 pm
Your CDI should be earthed to the frame. The white wire provides an earth via the stator base plate. You should also have a braided earth between engine and the frame.
Postby Kristof Lammy pie » Sun Mar 13, 2016 12:22 pm
Right so I don't think I've got any earth's apart from CDI to base plate.
Kristof Lammy pie
Postby Jazzy b » Sun Mar 13, 2016 1:32 pm
Have you tried another cdi as I posted above same probs as yours the CSI was breaking up new one solved it just a thought
Jazzy b
Postby Kristof Lammy pie » Sun Mar 13, 2016 1:37 pm
No I haven't got another one.
I've disconnected the green switch wire so I'm going to try that out now.
Kristof Lammy pie
Postby Kristof Lammy pie » Sun Mar 13, 2016 2:15 pm
Ignition wire disconnected and it runs fine! :D
So hopefully that's that sorted.
Many thanks everyone for helping.
Kris
Kristof Lammy pie
Users browsing this forum: Bing [Bot] and 10 guests
