temperature readings
Postby sjmooregt200 » Sun Mar 13, 2016 4:56 pm
hi been for a bit of a ride this morning and temperature gauge on the sip speedo with sensor on top of the plug
was normal riding with others say 40-50 mph was reading 170-175 degrees Fahrenheit
when I ragged it a bit on way home say upto 75mph it was hovering around 200 degrees Fahrenheit does this seem alright
plug chops etc all seem to be fine oh its ts1
cheer steve
sjmooregt200
Re: temperature readings
Postby Wack » Sun Mar 13, 2016 8:00 pm
Postby sjmooregt200 » Sun Mar 13, 2016 8:50 pm
cheers wack I'm only getting half those farenheit readings
sjmooregt200
Postby Nelly » Mon Mar 14, 2016 12:14 pm
Temperature readings can be a very grey area, depending upon your sensor position.
The temps Wack has posted are pretty accurate temperature areas for a sensor screwed directly into the head, as mine is. That's the chart I used to set mine up.
As an experiment I tried some back to back comparisons by swapping the cable from a sensor on the plug back to the sensor screwed into the head. It made a huge difference, obviously, as the sensor on the plug will receive some cooling from the air.
See the threads below for some good info. I never did get the engine set up after those posts as a piston ring decided to snap whilst setting the jetting up, so trying again soon with another fine set up by Mr Scott. A DT175 piston this time rather than a converted Asso. Cheers Scotty........nearly finished my uni work mate, not forgotten about your garage lighting upgrade :lol:
viewtopic.php?f=7&t=4137&hilit=+sensor
viewtopic.php?f=7&t=3779&hilit=+sensor
Nelly
Postby Scooterlam » Mon Mar 14, 2016 11:45 pm
Hi do you have a link to the screwed in sensor.
I've been looking at the m6 ones.
Scooterlam
Postby Nelly » Tue Mar 15, 2016 12:00 pm
That's just the one that came with the SIP speedo, you can buy them on their own from Beedspeed
https://www.beedspeed.com/speedometer-s ... 10211.html
Nelly
Postby Scooterlam » Fri Mar 18, 2016 9:10 pm
eBay 231168996853
I was thinking of this tapped in.
Scooterlam
Postby Nelly » Sat Mar 19, 2016 10:28 am
You will need to ensure the resistance span is the same as the SIP sensor otherwise you will get dodgy readings.
Also, bear in mind the sensor you are looking at is wider than the SIP one.
Other than that I really can't offer any more advice. It will be a case of trial and error.
Nelly
Postby Marty ULC » Sat Mar 19, 2016 10:55 am
Will the sensor on an SIP speedo fit the thread in the blanking plug on a GT porcupine head?
Marty ULC
Users browsing this forum: No registered users and 18 guests
