by pauLI » Thu May 12, 2016 2:28 pm
I have a series 2 and the front hub has some play where the large pin that must fit into a slot in the hub
is there a way of fixing this?
Are back plates interchangeable? or is it better to get a whole new complete hub
cheers
pauLI
by petemaisey » Thu May 12, 2016 3:24 pm
The hub's are like that. If it bothers you you can wrap the pin in PVC electrician tape to make it tight.
More importantly is to make sure your back plate is not a series 1 type, (unlikely), the cast alloy support for the slot must be as wide as the slot to strengthen it all. S1's were only half the width and the slot could snap apart when braking.
petemaisey
by pauLI » Thu May 12, 2016 3:44 pm
Thanks Pete
The MOT man mentioned it last week that's all
pauLI
by Tony Hart » Thu May 12, 2016 4:29 pm
Hi Paul
As Pete says you can put a few rounds of insulating tape around the peg on the link to make it a tighter fit in to the hub plate. I had one of the early back plates on a 1963 Spanish S2 so it is always worth a check. (You can get replacements for £10-15)
Tony
Tony Hart
by Wack » Thu May 12, 2016 5:46 pm
Just tighten the inner nuts up tight, then the backplate won't move backward and forwards.
by HxPaul » Thu May 12, 2016 5:57 pm
A friend of mine used a bit of copper pipe on the peg (the type you use in your bathroom/kitchen)Stopped it from moving backwards and forwards.
by steve t » Thu May 12, 2016 7:11 pm
Mine is the same so I just placed a piece of rubber round it . That got rid of the movement.
steve t
