Desperately need good news
Postby EricG » Fri Aug 05, 2016 11:57 am
Hi all: I've been in LCGB for some years but new to the forum.
I've just started to restore my SX 200 and was gutted to find the rot at the bottom of the frame - thought it was all solid.
Can someone PLEASE tell me that this can be welded or is it the end???
Eric
EricG
Re: Desperately need good news
Postby foremanbob » Fri Aug 05, 2016 12:01 pm
That can be welded no problem. But IMHO a good strong repair to that would not be invisible.
If you weld a plate over the top, that'll be fine and strong.
foremanbob
Postby bsso78 » Fri Aug 05, 2016 12:03 pm
It's hard to tell from a photo but on face value it can be repaired. Shaun Burns would be the man for that.
bsso78
Postby EricG » Fri Aug 05, 2016 12:07 pm
Thanks for that. I realise it's hard to tell from a photo but at least you've given me some hope.
Where is Shaun Burns based? I'm in north Leicestershire.
EricG
Postby EricG » Fri Aug 05, 2016 12:10 pm
The most important thing for me is to be able to rebuild her. Thanks.
EricG
Postby bsso78 » Fri Aug 05, 2016 12:16 pm
Shaun is in the north east,I'm sure someone will be able to give you his contact details. Welding a plate over the bottom is about as much use as filling the holes with plasticine. It needs cutting, sleeving and ring butts putting in then welding up on a jig.
bsso78
Postby dickie » Fri Aug 05, 2016 3:09 pm
Shaun is in Durham and is the man for the job. He has worked wonders for me.
He has an original frame jig from the eibar factory so you know it will come back straight and true.
I'll pm you his number
Postby Sticky » Fri Aug 05, 2016 3:15 pm
Shaun comes highly recommended, but since your frame is straight this is not a specialist job needing a jig. The question though is how much worse it is inside. Seen a few Lammy frames snapping recently so you have to make sure to cut all the rot out and replace with good metal or reinforce externally.
Got a welder I can recommend in Leicestershire if you PM
Sticky
Postby coaster » Fri Aug 05, 2016 4:18 pm
There a chap called Dean that does good work too, from the Scooterotica site http://www.scooterotica.co/forum/viewto ... 88#p144843
This was far worse that yours :shock:
Postby EricG » Sat Aug 06, 2016 10:20 am
Thanks for all that guys. Just trying to decide, which way to go with this.
EricG
Postby Rich Oswald » Sun Aug 07, 2016 4:20 pm
Kris Green @ Mental Engineering is closer to you, being in South Yorkshire.
Postby EricG » Mon Aug 08, 2016 3:32 pm
Thanks Rich
EricG
