Head cowl bolt/exhaust studs
Postby Revvers » Wed Aug 17, 2016 3:51 pm
Is it possible to tighten the exhaust nuts and replace the head cowl bolt, with the engine in situ?? Any top tips??
Revvers
Re: Head cowl bolt/exhaust studs
Postby Digger » Thu Aug 18, 2016 5:54 am
Yes
Take off the rear shocker, remove the spark plug and your exhaust which should give you room to take off the head cowling.
(On a normal sized head that is)
Digger
Postby Mark esq » Thu Aug 18, 2016 9:32 am
Removing the rubber bump stop will give you a few extra mm need if sliding cowling off.
Mark esq
Postby Warkton Tornado No.1 » Thu Aug 18, 2016 11:56 am
Post by Digger » Thu Aug 18, 2016 5:54 am
Yes
Post by Mark esq » Thu Aug 18, 2016 9:32 am
All spot on advice from experts ;)
It may be worth loosening the fasteners you speak of so that the exhaust sealing faces/gasket can be cleaned up/replaced/re-sealed prior to tightening up the exhaust properly... :!:
Postby Revvers » Thu Aug 18, 2016 5:44 pm
Thanks all
Revvers
Users browsing this forum: No registered users and 15 guests
