Front disc brake kit
Postby jefft » Mon Jan 30, 2017 11:36 am
Hi again,
Can anyone recommend a complete front disc conversion kit for a series 3 li125 Special (now 185) I want to keep with the original style lever and light switch setup but would also like the anti dive facility. Any views and comments please.
Jefft
jefft
Re: Front disc brake kit
Postby ULC Soulagent » Mon Jan 30, 2017 12:16 pm
If your wanting keeping the original lever then semi hyldrolic is the only option I believe (I stand too be corrected)
ULC Soulagent
Postby jefft » Mon Jan 30, 2017 12:43 pm
Hi,
Sorry , what I meant was I didn't want to go for the black type lever just the polished alloy type.
Jefft
jefft
Postby Warkton Tornado No.1 » Mon Jan 30, 2017 2:51 pm
Post by jefft » Mon Jan 30, 2017 12:43 pm
Hi,
Jefft
This is not a recommendation, but you seem to be asking for Reader suggestions as, actually, this is the type of thing you wish to include:
https://www.lambretta-teile.de/Master-c ... X-TV-GP-dl
Last edited by Warkton Tornado No.1 on Mon Jan 30, 2017 5:22 pm, edited 1 time in total.
Postby corrado » Mon Jan 30, 2017 4:45 pm
jefft wrote:Hi,
Jefft
Do you want a master cylinder on your headset? Normal outboard ones comprise of an adapted light switch housing [you have to remove the existing one] with a Black master cylinder attached to it, the brake lever can be Black or polished. ScootRS ones no longer appear to be available, they had a polished lever, most are only selling the Sterling / Spaq ones these days and they come as standard with a Black lever, although they do sell a polished lever separately.
Also now available is an adapter that bolts onto your existing light switch housing [saves you having to remove your existing light switch and wiring], again these are Sterling / Spaq items that have Black master cylinder and lever.
If you want to leave your headset untouched then you need to go for a hidden master cylinder.
Sterling also produce a hydraulic inboard disc [to suit drum links] again with options of headset mounted master cylinder or hidden master cylinder. This is the nearest you'll get to standard looks.
corrado
