chrome frame collar fitting
Postby mr mugello » Wed Feb 22, 2017 7:11 pm
Will cooling metal chrome collar in a freezer help ease fitment in the frame tube ?
mr mugello
Re: chrome frame collar fitting
Postby Knowledge » Wed Feb 22, 2017 10:36 pm
Worth a try, but if my experience of getting one out last week was not fun.
It is brittle, so don't hit it too hard.
Postby mr mugello » Mon Feb 27, 2017 4:08 pm
Original rechromed fitted back in a lot easier than getting out. Well worth the hassle removing. Religning the grub screw with hole I was concerned with messing up, but able to push in frame by hand three quarters of way.
mr mugello
Postby Phil D » Mon Feb 27, 2017 5:08 pm
mr mugello wrote:Original rechromed fitted back in a lot easier than getting out. Well worth the hassle removing. Religning the grub screw with hole I was concerned with messing up, but able to push in frame by hand three quarters of way.
Just out of interest what's the going rate for a C/R re-chrome at the moment?
Phil D
Postby mr mugello » Wed Mar 01, 2017 11:52 am
Spoke too soon. Every thing was going well. Fitting headset bottom, the gap is not even. One side is up to 2mm roughly different. Never noticed this before removal, but my eye picks up these when refitting. Bit annoying. Can either headset clamp and collar be prone to distorting even though cast items ? Thanks
mr mugello
Postby Warkton Tornado No.1 » Wed Mar 01, 2017 3:52 pm
Even with non-chrome ring headsets you might need to adjust the seating of the headset by fitting shims (washers) of varying thicknesses between the headset casting & the headset clamp. It can take considerable time to get the fit right.
You can’t just ‘assemble‘ Lambrettas, you have to ‘fit’ them.
It wouldn't be the first time that the slot in the fork (where the clamp screw engages) has had to be widened upwards or downwards to allow a better fit of the headset to the leg-shields....
Postby mr mugello » Wed Mar 01, 2017 4:25 pm
paid £23 including postage at Quality Chrome Hull.
mr mugello
Postby mr mugello » Wed Mar 01, 2017 4:26 pm
Warkton Tornado No.1 wrote:Even with non-chrome ring headsets you might need to adjust the seating of the headset by fitting shims (washers) of varying thicknesses between the headset casting & the headset clamp. It can take considerable time to get the fit right.
Thanks will give shims ago.
mr mugello
Postby Warkton Tornado No.1 » Wed Mar 01, 2017 4:42 pm
Perhaps this is ‘too much’ information, but as I have the Helicoiling kit to hand, I have from time to time, Helicoiled to M6 so avoiding having to use nuts @ the bottom. Just screw straight into the clamp, preferably with an M6 SHCS (Socket Head Cap Screw). Now, that does make life a lot easier, especially when shimming!
Another one of my ‘Top Tips’ :roll: Hah!
Postby mr mugello » Thu Mar 02, 2017 11:40 pm
Fitting a thin shim through one of the bolts between headset base and clamp bracket done the trick.
mr mugello
Users browsing this forum: No registered users and 32 guests
