Captain Pugwash wrote:Jet it same as a 200 main jet usually between 118-125, if it bogs down at low speeds try a 150 slide, if the idle won't settle coming off the throttle try a 48 pilot jet.
There all a little different depending on porting and cylinder head, most seem to run skimmed and reprofiled high comp 150 heads. The 175 head gives a more useable compression ratio when skimmed and reprofiled.
Ive actually got two 190 barrels that I need to port ASAP. I've only just got the cylinder heads back after getting them skimmed and reprofiled ones is from a 150 the other ones a 175 head.
I will try and upload a couple of pics to show the difference.
Cheers, Mark.
Captain Pugwash wrote:That looks well ported and quite a large inlet port on the shortened barrel, is there a tuners name on the barrel?
if you look on AF Rayspeed's website you'll see that they sell a stepped pin to allow the 'older' webs to be used with the con rods that require a Ø22 mm diameter to function.
Users browsing this forum: Bing [Bot] and 15 guests
