How much left/right play should their be on an Li Clutch Basket/rear sprocket?
if any...
that's the whole big cog part...
As its rocking a few mm from side to side
That's the basket and sprocket wobbling, not the plates..
Thank you
HxPaul wrote:From the video it looks like the centre of the clutch basket is worn,or the bearings.Their is a shim that goes on before the spider,most Lambretta shops sell different thicknesses of shims to align the chain.
ladsdad wrote:Hi mate
If you have Sticky's manual have a look at the pages showing clutch sprockets. If, in the centre where the clutch plates fit, you can see a rivited on plate, that's a sprocket with a cushdrive.
Users browsing this forum: Google [Bot] and 18 guests
