by MK Monty » Mon Apr 10, 2017 10:09 pm
Ha Ha I did the same but was buggered as the ball had a bloody big hole in the underside, No problem he thinks I will fill it with my trusty mig welder. It went well and just needed a bit more so I could file it down, when my ball fell off.
Story of my life
MK Monty
by mr mugello » Tue Apr 11, 2017 5:50 pm
I see , thanks
mr mugello
by Andie » Fri Jun 16, 2017 11:20 am
Did you manage to resolve this Mr Mugello?
I am asking as I am thinking of changing my clutch activator arm orientation, clutch plates and springs as I suffer from the same problem - my clutch has to be so taut (to prevent drag) that it's wearing the cable and my fingers out. Also changing gear is an art form in itself.
Andrew
Andie
by Rich Oswald » Fri Jun 16, 2017 11:58 am
Andie wrote:Did you manage to resolve this Mr Mugello?
Andrew
I was having the same problem on the new J engine so changed to AF Cassette Road clutch and longer dog leg lever and it's fine now,
by mr mugello » Fri Jun 16, 2017 8:58 pm
Andrew
I bought a set of Camlam's Ultimate soft springs. Still sitting in packet though. Reason being I changed my seat which has helped with my hand ligament strain. I originally had an Elvington short race seat. With my arms fully outstretched in sitting position, putting strain on hand when changing gear. Now using a dual seat and sitting further forward has stopped ligaments over stretching. Sounds unbelievable to find easier clutch use by changing seating. Works for me anyway. Not had problem since. Obviously the clutch is still stiff and a spring change will hopefully improve movement even better.
mr mugello
by peejay » Sat Jun 24, 2017 12:16 am
HxPaul wrote:https://www.beedspeed.com/lambretta-clutch-easy-clutch-small-universal-type-p-1474.html
This gives you an idea of how they work,but you can buy them cheaper elsewhere
thought this was the answer for me, i honestly couldn't feel the difference, another top shelf dust collector
by Adam_Winstone » Sat Jun 24, 2017 12:28 pm
I don't have one of those....
... but "another top shelf dust collector"... I do have plenty of those!
by Martin FONSC » Sun Jul 02, 2017 6:48 pm
If you have the cash I would recommend the Rayspeed clutch. I am running the race version in a modified TS1 with no slip and not too much lever effort. Also using a dog leg lever and low friction cable. One final thing check your cable run as this can also affect your clutch lever effort - you need to have no tight bends or kinks in the cable.
Martin FONSC
by Scooterlam » Fri Jul 21, 2017 10:35 pm
Yoga or physio.
Cure the problem not the symptom.
Scooterlam
by mr mugello » Sat Jul 29, 2017 7:42 pm
Just an update after fitting the set of Ultimate Soft Feel Springs. Still heavy clutch. No noticeable difference to the old uprated springs that were fitted. Moved clutch arm a notch closer forward to more of a 90 degree angle to cable. Did read recently on another post about spring tension that MB springs were showing slightly lighter than Ultimate set so worth a try with these next strip down I think.
mr mugello
Users browsing this forum: Bing [Bot] and 5 guests
