SIO DC RPM, Ignition timing.
Postby Delboyli150 » Fri Aug 04, 2017 10:27 am
Hi Guys
Can any of you clever lot inform me, will a full DC Wassel Conversion interfere with the ignition timing? See 'Sip2 Installation' If need full details.
I have joined the Brown RPM of the Sip 2 to one of the yellows from the Stator (BGM DC) this was the only way I could get correct and stable RPM, would this have any bearing on the Ignition Timing especially on High RPM?
Delboyli150
Re: SIO DC RPM, Ignition timing.
Postby coaster » Fri Aug 04, 2017 12:52 pm
No, that will work fine and is what I have on my LiS, full DC with Wassel conversion and RPM wire attached to a yellow before the Wassel unit. Works fine 8-)
Postby gp200ts1 » Fri Aug 04, 2017 1:49 pm
Won't affect timing at all. The dc wiring and coils are totally separate to the ignition system
gp200ts1
Postby Delboyli150 » Fri Aug 04, 2017 8:19 pm
Thanks guys
Just clutching at straws then! Installed Mugello 198 and Gori 50 only pulling 60, been dyno'ed at CS. Will investigate further....
Delboyli150
Users browsing this forum: gp200ts1 and 11 guests
