I applied 55mm wide stripes behind the plastic panel grill, but when I went to apply the short stripe in front of the grill, it looked wrong. I dug-out a 60mm (wide) panel stripe that I had in stock, and used this forward of the grill. It looks correct.
So I am wondering if the panel stripes should be 60mm wide ahead of the grill, and 55mm behind the grill.
Has anyone got original panel with an original stripe that can measure the width of the panel stripe both ahead and behind the panel grill?
