Garmin Forerunner mounting options
Postby DaveTomo » Mon Jul 30, 2018 10:55 am
After years of a geiger counter speedo, I'm going to embrace modern technology and get a forerunner.Basically something I take off when using the scoot for day to day stuff, but on longer distances it would be nice to know what speed I'm actually doing.My speedo is Ok up to about 50MPH after that it goes wild.For example I overtook a scooter going down to Exmouth on the M5 over this last weekend, saw them at the services later,was asked how fast were you going? My reply" I have no idea anything between 40 and 70".
So how do people mount them ? I don't have a legshield tool box so would need to be handle bar mounted or can you just use the strap and secure it to the headset or maybe onto the spare wheel? Any help or pointers appreciated
DaveTomo
Re: Garmin Forerunner mounting options
Postby Knowledge » Mon Jul 30, 2018 12:48 pm
I have a Forerunner 201, and I have just strapped it around the headset, by the light switch. If you put it any lower, it will be a pain to read.
The Velcro strap making fitting an removal a doddle.
Mind you, have you thought about an SIP speedo? They are a good bit of kit and give you a lot more info than just speed.
Postby coaster » Mon Jul 30, 2018 12:51 pm
Most have them strapped to the bars to the left of the switch housing. They aren't advertised as waterproof though, just water resistant, I mounted mine on a bracket mounted inside my Coast to Coast screen and wired into the DC on the scoot and it was fine for a few years left in place all the time.
Postby AlG » Mon Jul 30, 2018 1:05 pm
I use the Forerunner 201, set up for MPH and distance, also using the velcro strap wrapped around the headset next to the light switch. I bought a couple from that auction site and just keep one on the scoot and another on charge then swap them out when needed. Sometimes takes a few minutes for them to find a satellite, but if I switch it on as I open the garage, then by the time i have kicked the scoot over the Forerunner is ready to go.
AlG
AlG
Postby rossclark » Mon Jul 30, 2018 1:08 pm
No sign of any lack of waterproofness on mine - I used it on the Celtic Dash this weekend and some of the weather was biblical...
This one - 205 - I found was generally cheaper on the second hand market than the 201
Postby DaveTomo » Mon Jul 30, 2018 3:01 pm
Thank you chaps - appreciate the response.Don't why I thought it needed some type of bracketry, so jobs a good un.
Martin have thought about a SIP speedo but to be honest the Garmin seems the cheaper option.
Just have the feeling now I will be utterly dissapointed at how fast (or not) I am actually going :lol:
DaveTomo
Postby Knowledge » Mon Jul 30, 2018 3:40 pm
Reality may bite.
Postby Andy_S » Mon Jul 30, 2018 4:34 pm
Always worth checking the CEX website, as the prices seem cheaper for forerunners than the auction site.
Andy_S
Postby rossclark » Mon Jul 30, 2018 4:47 pm
DaveTomo wrote:Just have the feeling now I will be utterly dissapointed at how fast (or not) I am actually going :lol:
Yep
Postby burnside » Tue Jul 31, 2018 11:57 am
On the subject of forerunner 201, does anyone know where you can get a replacement charger, or have found an alternative charger that fits and works?
burnside
Postby coaster » Tue Jul 31, 2018 12:49 pm
burnside wrote:On the subject of forerunner 201, does anyone know where you can get a replacement charger, or have found an alternative charger that fits and works?
I might have one you can have Ross, I'll have a look at the weekend, was it the charger itself or the cradle?
Postby AlG » Tue Jul 31, 2018 6:13 pm
AlG
Postby burnside » Wed Aug 01, 2018 8:50 am
Cheers Colin. Just the charger, I have a cradle
burnside
Postby burnside » Wed Aug 01, 2018 8:51 am
Thanks, I may have to buy that if Coaster's search comes to nothing
burnside
Postby Knowledge » Wed Aug 01, 2018 1:21 pm
^ I purchased a USB lead that goes straight from any phone charger to the cradle. It works a treat, and is something else less to carry around with you.
It also means you can charge the Forerunner from a USB battery-pack when there is no mains available
Postby burnside » Wed Aug 01, 2018 4:12 pm
Knowledge wrote:^ I purchased a USB lead that goes straight from any phone charger to the cradle. It works a treat, and is something else less to carry around with you.
Hi Martin, do you know what the connector type/pin diameter is for the Garmin cradle end?
burnside
Postby Knowledge » Wed Aug 01, 2018 9:40 pm
It is about 2.4 or 2.5 mm OD, but the pin up the middle is less than 1mm.
I hope this helps.
Postby burnside » Thu Aug 02, 2018 10:23 am
Cheeres martin, I've ordered a couple of cheapies to see if they fit
burnside
Postby DaveTomo » Tue Aug 14, 2018 6:55 pm
Just thought I'd follow up on my original post - bought a Garmin 205, its a bubble burstin' bit of gadgetry but at least now I know how fast I'm not going :lol: :lol:
Image20180813_133301 by Dave Tomlins, on Flickr
DaveTomo
Postby rossclark » Tue Aug 14, 2018 9:54 pm
Yep, I've checked it against strava and runkeeper and the car speedo ( which I know to be 3mph fast) and sadly it's very accurate :lol:
Users browsing this forum: GrayB and 15 guests
