Should the rear footboard hangers be welded to the outriggers?
And should engine mount cones be tight in the mounting hole?
drivera wrote:Left side footboard hanger is welded but kickstart side should be bolted in to help with side case removal , engine cones can be a very tight fit , try tapping out from the other side with a long drift or long screwdriver
Warkton Tornado No.1 wrote:The engine cones should be fitted with a good grease, as any cone IMHO, & I use Copalip as it stays the course.
A few times, I have carefully removed the LH dogleg & made it removeable as per the RH side. The strut should also be slotted as per the RH side. (BTW, captive rivet nuts on any dogleg is a timesaving improvement, saving fiddling about with nuts & washers on the back face)
This enables a great ‘cheat’ in alignment of the footboard/side-panel gapping, for which I am sure we are far more critical of than when our Italian shopping machines were conceived & built
Users browsing this forum: No registered users and 180 guests
