skinnerwill wrote:wonder if you got it same place as me, i did send mine back.
i got new one from rayspeed , not perfect but a damn site better than other one
vegansydney wrote:Buy a used Innocenti one. At least it will fit! If you have an eye for details, production changed to the SX/GP type in late '65, everything earlier had the standard S3 type.
landybretta wrote:
The lip on the brake shoes suggests that the hub is not fully seated when tightened.
The cone is slightly loose on the splines and is fully home. Can be spun round by hand.
Any suggestions as to what the problem may be would be appreciated.
The hub and matching cone were purchased from a reputable supplier.
No problems with the previous hub which I believe was an original part. (I damaged it unfortunately).
Storkfoot wrote:When you say the hub is out of true, how do you come to that belief? Are you keeping your eye on the outer edge of the hub itself as it rotates? Or, as is visible on one of mine, is the brake shoe visibly not engaging with part of the inner track?
If you tighten the hub up to the proper torque setting, with the shim under the cone, is there any play if you grab at the hub, other than the normal “give” you get from the rear hub bearing?
Has the hub ever come loose? I ask as I would have thought that if you have an incorrectly matched cone, the hub would move and you may initially feel this by the brake coming on and making the hub hot.
I have seen the outer lip on plenty of my shoes in the past and never thought anything about it. I may be wrong though. The cone on the layshaft, with the hub off, is not especially tight. You can normally take it off with your fingers.
Having asked all these questions , I do recall reading posts about Scootopia hubs not, at one time about 3 years ago, being a brilliant match with their cones
Since Uni started making hubs several years ago, I have used them without real issue. FA Italia were the generally available ones previously. Uni are much better made, in my opinion. The only issue I have come across with Uni ones is that the inner track does not always engage 100% with the shoe throughout its rotation.
Fast n Furious wrote:The easiest way I find to make certain that the cone is the right one for a hub (old or new), is to lap the cone to the hub with some grinding paste. I have a rubber ball with a bolt through the centre. My pistol drill grabs and spins the cone nicely with this simple tool in both directions.
If I only get a thin grey line then it's the wrong cone for that hub. A line almost as wide as the cone itself is what I'm looking for. 1 in 3 chance of getting the right one.
Warkton Tornado No.1 wrote:The more I look @ the image of the hub with the cone in, the more I am convinced:
'That looks like the wrong cone for that hub & I'd be surprised if the tapers match'
landybretta wrote:Storkfoot wrote:When you say the hub is out of true, how do you come to that belief? Are you keeping your eye on the outer edge of the hub itself as it rotates? Or, as is visible on one of mine, is the brake shoe visibly not engaging with part of the inner track?
In answer to your questions.
Maybe out of true was not quite the appropriate wording but one of the brake shoes is not visibly engaging with part of the inner track. When braking the shoes grab and braking is not progressive. Very easy to lock up. Same brake set up as with previous hub with no problems.
When fully torqued there does not appear to be any abnormal movement.
The hub has never come loose but I have not done a lot of miles since it was fitted due to the pandemic etc.
Did not have a lip on the brake shoes with the original hub. The cone on the layshaft is a loose fit. When the hub is removed the cone comes of attached to the hub and is a tight fit and has to be knocked out.
The hub and cone were purchased from the supplier you mentioned about 3 years ago.
Users browsing this forum: No registered users and 56 guests
