scootersi wrote:....I'm pretty sure the carb is delivering enough fuel as it's been on the scooter for a while and this is a relatively recent issue.
Knowledge wrote:The issue might be related to the tune of the scooter. There might not be enough torque at road speeds to overcome the gap between 3rd and 4th gear. If there isn't enough torque, then you will be fighting a losing battle in 4th as the power slips away, leaving you hunting for 3rd gear to get up inclines and hills. If it seems OK (and even great) once back in 3rd, then it might be an issue with the tune rather than the settings.
You can reduce the symptoms by down-gearing, but you will reduce the top speed or run at higher revs at speed. This may not be desirable.
I have written about this very problem in the next edition of Jetset, which is with the printers.
Users browsing this forum: No registered users and 115 guests
