by Stesjh » Fri Dec 28, 2018 11:28 pm
Looking for a bit of advice. Currently building a S2 and have noted there is limited space in the headset for additional cables and wiring. Try to add hydraulic cable and wiring plus thumb choke. Is it me or is there a lot less space compared say to a GP? Any solutions would be most welcomed.
Stesjh
by Norrie Bodge » Sat Dec 29, 2018 9:58 am
Loads of room
I run hydraulic/thumb choke/CHT & Rev counters
Norrie Bodge
by Stesjh » Wed Jan 02, 2019 4:20 pm
Norrie Bodge wrote:Loads of room
Did you have to modify anything?
Stesjh
by Toddy » Thu Jan 03, 2019 7:20 am
I run similar to Norrie heres how ,
Thumb choke runs through Hole in the headset bottom along side the hgeadset clamp bolt
Clutch cable normal route
Hydralic disc cable comes up at the Front of the headset with a small fettle to allow movement
Wiring loom and extras come up the side of the gear wheels
i also have an ignition in mine as well
Hope this helps Toddy
by shane BBoys » Thu Jan 03, 2019 8:50 pm
Toddy wrote:I run similar to Norrie heres how ,
Paul do you have a couple of photos as they may come in handy for my ongoing project?
Cheers Shane
shane BBoys
by Toddy » Thu Jan 03, 2019 11:45 pm
Cheers Shane[/quote]
Here you go buddy not finished yet but shows what you need
by Stesjh » Sun Jan 06, 2019 5:26 pm
Many thanks for the pictures, very helpful
Stesjh
by Norrie Bodge » Mon Jan 07, 2019 8:01 am
heres mine they may help
Norrie Bodge
by Tractorman » Mon Jan 07, 2019 10:15 am
You will make more room if you remove the wiring junction block.
by Toddy » Mon Jan 07, 2019 10:18 am
Tractorman wrote:You will make more room if you remove the wiring junction block.
Agreed I’ve had to do that to fit my jockeys headlight
by foremanbob » Mon Jan 07, 2019 1:47 pm
Stesjh wrote:Looking for a bit of advice. Currently building a S2 and have noted there is limited space in the headset for additional cables and wiring. Try to add hydraulic cable and wiring plus thumb choke. Is it me or is there a lot less space compared say to a GP? Any solutions would be most welcomed.
How about going left field and fitting a remote hydraulic master... can thoroughly recommend the Oiltek unit that mounts under the floor on the LHS of the scoot.
Lovely bit of kit
foremanbob
Users browsing this forum: No registered users and 59 guests
