dickie wrote:I have an inboard front disc. At high speeds it works pretty well. At low speeds it is on/off causing the front to bounce up and down.
I've only experienced this on old worn discs on other bikes but this brake is only about 400 miles old. I haven't inspected the disc yet.
Any ideas?
I think the OEM discs were made of iron & quite probably would have been cast, allowed to 'rest' out in all weathers to relieve stress, then machined.
The disc you have may have not followed the same procedure & is now warped. You could try getting it skimmed in a lathe, but depends upon the amount of warping. If you have 'worked' the brake, then there shouldn't be any more material movement to come, so shouldn't warp further. It would be interesting to know if warping is the problem & if so, how much the run-out is.
I hope any replacement doesn't end up doing the same
