mickey c wrote:Thx for the replies. I pretty selector is correct way, the pivot is closer to rear wheel than trunion holes when in neutral.
The gear selector arm being to wide intrigues me. I’ll check the and detach it. Any other ideas beforeI strip the gearbox down?
dscscotty wrote:is it a new gear swivell and tie bar? there's been some issues with MB and JPP ones, in that the bar hits the swivvell, and stopping the movement
neily03 wrote:dscscotty wrote:is it a new gear swivell and tie bar? there's been some issues with MB and JPP ones, in that the bar hits the swivvell, and stopping the movement
I had that problem with a JPP one, complete garbage. Had to file the swivel so it clears the bar so I could select 1st gear....
mickey c wrote:bearing in mind this project has taken me about two years, four weeks to update on this is good for me!
it turned out that I had positioned the gear selector arm about 45 degrees out. I re-did this with the gear selector at 90 degrees to the chain case when in 2nd gear. took it up the road and I now get all four gears, nice and smooth too. I'm made up I have not had to get the engine apart and am hoping for a MOT this week.
thanks again everyone for your help!.
Users browsing this forum: Google [Bot] and 36 guests
