hullygully wrote:I've just found the same problem with my TS1, fine when cold, but racing after 3 or 4 miles, being driving me crazy for 2 months of plug chopping, stator changes, pilot swopseys, carb changes, CDi swops, plugs............................... then noticed a fuel bubble from one of my cyl hd nuts on tickover, all nuts still torqued down, so top end strip
nickwill wrote:Hi, I would suggest going back to whoever fitted the kit if that's possible, at least they should still be familiar with your engine and setup.
I've spent many hours trying to sort out problems and ended up wasting time and money barking up various 'wrong trees'. Educational but frustrating.
Nick
MickYork wrote:What is your carb set up ....jets, needle, slide, etc
It's possible your pilot is too big ?
coaster wrote:You really need to find out what needle and atomiser you have, no one can give meaningfull advice without although I suspect yout pilot/idle jet is a tad small, thought 55 was more or less standard on most kitted lammys
Warkton Tornado No.1 wrote:coaster wrote:You really need to find out what needle and atomiser you have, no one can give meaningfull advice without although I suspect yout pilot/idle jet is a tad small, thought 55 was more or less standard on most kitted lammys
Really?
Piston ported will tend to have a smaller pilot than reed valve engines. More so if an air filter is fitted.
Simply because all engines have a start & stop point of tick over speed, I think it worth the time setting up the preliminary jetting. IMO there are a lot of 'tuned' engines set up far too rich. Atomisers are yet another example of oversizing, as the smallest possible should be used to allow the engine to run WOT with no main jet to allow the finer, incremental control of fuel delivery. There is no point in oversizing unless it helps bragging down the pub
On occasion with full race Group Four top ends, pilots have been dropped down into the thirties....
coaster wrote:Warkton Tornado No.1 wrote:coaster wrote:You really need to find out what needle and atomiser you have, no one can give meaningfull advice without although I suspect yout pilot/idle jet is a tad small, thought 55 was more or less standard on most kitted lammys
Really?
Im always happy to be corrected but I undertood that going too small on the pilot was dangerous on a road bike as if the throttle is closed after a high speed run a weak condition can occurr. Could be miss remembering about the 55 pilot but pretty sure thats all I've ended up with.....could explain why I tend to use more fuel than others I ride with
Fast n Furious wrote:Here we go again.......
The most unreliable new lambretta part on the market rears its ugly head once more.
It is absolutely essential that the LT coil on any elctronic ignition stator plate is reworked before using it.
It really is absolute "pot luck" if yours has been trouble free.
They all have an inherent construction flaw irrespective of who made it or who sells it or what fancy box it comes in.
Saying all that........ the symptoms you describe in yout posting are not really consistant with the diagnosis but then these shit stators can throw up some very erroneous wobblies..... Hmmm.
lam1962brettagg wrote:Fast n Furious wrote:Here we go again.......
thanks for the comment, I never realised stator LT coils were so crap.
can I ask how its to be 'reworked?' please. not sure if the dealer has done anything to it b4 fitting it.
cheers
