by superhooper » Sun Jan 23, 2022 7:30 pm
Whilst prizing the rear hub bearing oil seal out we noticed that the outer bearing itself would rotate in casing. There is no actual play but it's not an interference fit. We refitted it with a bead of locktite around the edge. My question is, is this an exceptable fix? I can't be arsed to strip engine again.
Your expert opinions will be greatly appreciated!
Super
superhooper
by tv175lambretta » Sun Jan 23, 2022 7:44 pm
I think that any movement would inevitably lead to wear and then excessive play. And there isnt much backup/plan B with a rear hub bearing if it goes.
tv175lambretta
by nsaints » Sun Jan 23, 2022 8:48 pm
You need the right grade or strength of loctite for this
I had an engine mount that just dropped in once. It was fine and never moved once fitted using the correct grade retaining compound.
I just had a quick lookup on the loctite site and looks like you need to consider loctite high strength retaining compound 638
nsaints on Sun Jan 23, 2022 9:00 pm, edited 1 time in total.
nsaints
by superhooper » Sun Jan 23, 2022 8:56 pm
Thanks peeps
Super
superhooper
by hullygully » Mon Jan 24, 2022 1:34 pm
you could allways gouge some grooves where the bearing sits in the casing then add loadsa loctite & sealant
buuuuuuuuuuuut I'm sure Broady does a slightly oversize brg for this instance
by superhooper » Mon Jan 24, 2022 7:21 pm
Once again, thanks!
Super
superhooper
Users browsing this forum: martyn dwane and 49 guests
