by kevspeed » Thu Apr 14, 2022 3:50 pm
Anybody know if there is a press on bush available to fit over the 'knuckle' that slots into the front hub backplate to stop it knocking?
kevspeed
by duncan1958 » Thu Apr 14, 2022 6:33 pm
I cut a slither from the side of a can of pop.
Seems to do the job.
duncan1958
by Wack » Fri Apr 15, 2022 8:27 pm
Tighten the axle inner nuts real tight then you won't get the knocking.
by L111amo » Sat Apr 16, 2022 9:49 pm
A bit of rubber fuel pipe heated up. Does the trick
L111amo
by kevspeed » Mon Apr 18, 2022 12:01 pm
Hi all,i managed t get a small peice of copper pipe into the gap,it seems ok for now fingers crossed!
kevspeed
Users browsing this forum: No registered users and 51 guests
