dickie wrote:Try removing the wires. Then use a multimeter on the ohms scale and check that when you operate the switch it doesn't connect the incoming supply to the switch to ground.
dickie wrote:That means that when you press the pedal, the 2 outer connections are connected together; this is what you want.
So, connect one lead to earth or battery negative and the other to the switch terminal. It should say something like infinity (figure 8 on its side, or OL which means overload).
Try that and report back as detailed as you can please and we'll sort it.
dickie wrote:OK. Put the meter to DC voltage range. Black lead on battery negative and red to switch terminal.
On one terminal, it should show 12V all the time. On the other terminal it should only show 12V when the switch is operated.......
Lord-Spanner wrote:Turns out after testing every connection (all 3) (wires dissed) is to the switch pin when the pedal is depressed, hence the short on the brake pedal when the switch pin comes out....... surely the switch is shagged
dickie wrote:Lord-Spanner wrote:Turns out after testing every connection (all 3) (wires dissed) is to the switch pin when the pedal is depressed, hence the short on the brake pedal when the switch pin comes out....... surely the switch is shagged
You're right, it's goosed.
One of the pins, the one on the load or brake light side of the switch has an internal connection to the activation pin. It obviously shouldn't. You can prove this by using your meter on ohms and measuring between the activation pin and the electrical connection pin. You may have to press the pin to see this.
dickie wrote:Glad it's sorted.
Users browsing this forum: No registered users and 153 guests
