by gizmo » Sun Oct 08, 2023 8:36 pm
Any suggestions on who's are best fit at present. Last couple I've had have been borderline too tight. NOS ones are still available as an option
gizmo
by gaz_powell » Sun Oct 08, 2023 9:42 pm
Just bought a full kit from AF, not tried it yet..... Hoping all okay, be a while before it goes together.
Same kit on my last SIL frame and no problems on that... But that was a while ago
by bookertmgs1 » Tue Oct 10, 2023 4:59 pm
I bought a scootopia one last year & had to get it turned down by a local engineering place
Thankfully I'd kept the original so I had a reference to compare against once I'd discovered it didnt fit.
School boy error on my part not measuring before i attempted to fit it - should have know better that the chances of it being right were slim.
bookertmgs1
by gizmo » Tue Oct 10, 2023 5:15 pm
bookertmgs1 wrote:I bought a scootopia one last year & had to get it turned down by a local engineering place
I would be surprised if all frames are the exact same diameter so we are all on a loser to start with. I noticed allstyles do a re- machined one for a better fit. Might plump for a nos one
gizmo
by Lord-Spanner » Wed Oct 11, 2023 7:31 pm
I tried cheap and nasty first (big mistake), seemed to be way to tight to start with so canned them and bought a new old stock full race kit
Lord-Spanner
by gizmo » Sat Oct 14, 2023 2:33 pm
Lord-Spanner wrote:I tried cheap and nasty first (big mistake), seemed to be way to tight to start with so canned them and bought a new old stock full race kit
Just done same. Plus the bottom cup is the shallower depth not like most of the remade higher type
gizmo
by Fast n Furious » Sat Oct 14, 2023 4:28 pm
The nominal diameter of the bearing cup spiggot is 42mm.
There are minor differences in fork tube diameters depending on where and when the frame was made! There are also minor differences in the spiggot diameters of replacement bearing cups.
Almost always I find it necessary to skim the spiggot down in the lathe so that it fits easily using a lump hammer and a block of wood along with some loctite bearing fit. It's quite rare to find a replacement cup that fits "off the shelf" in my experience.
You don't need to use any heat. Freezing the cup before fitting does help, but not much.
If the fit is too tight, you risk splitting the fork tube by forcing it in and it also makes it a bastard to remove again.
by gizmo » Sat Oct 14, 2023 5:07 pm
Fast n Furious wrote:The nominal diameter of the bearing cup spiggot is 42mm.
Sound advice
gizmo
Users browsing this forum: No registered users and 117 guests
