jonno wrote:Got scooter out of hibernation and found the rear stop/tail light blows before I even w=switch on the lights. Is this down to just a poor earth ?
coaster wrote:Just to clear up a bit of confusion in the suggestions given, a short circuit will NOT cause bulbs to blow. My money would be on a corroded contact in the lamp unit, either the bulb contacts or the bullet connectors. It could also be in the headset or the brake light switch. Poor earth somewhere is also worth checking out as already mentioned. The dim light issue also points towards a bad earth.
MickYork wrote:coaster wrote:Just to clear up a bit of confusion in the suggestions given, a short circuit will NOT cause bulbs to blow. My money would be on a corroded contact in the lamp unit, either the bulb contacts or the bullet connectors. It could also be in the headset or the brake light switch. Poor earth somewhere is also worth checking out as already mentioned. The dim light issue also points towards a bad earth.
He says it blows bulbs without the lights being switched on...........makes me think the switch must be part of the cause
Meds wrote:..................... If that were the case then power has to be coming from somewhere, ie a short
Users browsing this forum: Google [Bot] and 51 guests
