Little end bush lubrication
Postby bordercot196 » Thu Apr 25, 2019 12:36 pm
Working on my 1954 D125 MkII I've discovered that the little end bush was worn and wanted changing. (14mm pin). I've fitted a new bush but noted that whilst doing that there are three small holes drilled radially through the little end of the con rod on its centre line. The bush OD blocks off these holes. Why are they there ? If they were drilled through the bush they could possibly provide some lubrication for the small end gudgeon pin however, the old bush I removed didn't have any corresponding holes. Is this why it was worn ?
bordercot196
Re: Little end bush lubrication
Postby jbcollier » Thu Apr 25, 2019 2:35 pm
I would drill them and chamfer the holes.
jbcollier
Postby bordercot196 » Fri Apr 26, 2019 9:25 am
Thanks job. Can’t see any other reason for these con rod holes, I’ll drill them through. Should help in getting some oil to the gudgeon pin.
bordercot196
Return to Pre 57
