1955 Model D 150 - Unidentified tab washer
Postby Big Al » Mon Jan 18, 2021 9:19 pm
I have an old tab washer which was bagged up with the torsion bar, the two torsion bar washers and the two circlips.
I already have the two tab washers for the figure of eight link, so what is this "spare" tab washer for please?
(I have emailed a photo to John Collier and hope he can post it here for me.)
Big Al
Re: 1955 Model D 150 - Unidentified tab washer
Postby jbcollier » Mon Jan 18, 2021 10:24 pm
jbcollier
Postby jbcollier » Mon Jan 18, 2021 10:28 pm
Looks like a lock tab washer for a crank nut to me.
jbcollier
Postby Big Al » Tue Jan 19, 2021 10:40 am
Thanks John.
I couldn't find anything like that in my official UK Lambretta Parts Catalogue for the 150 LD & D, but there is a Vespa drive cog nut locking tab washer for the 50/90/Primavera/PK which looks very similar.
http://www.discodezscooters.co.uk/p/ves ... imavera_pk
I'm not clear why anyone needed to use it on the torsion bar assembly, but I will bin this unwanted part!!
Big Al
Postby Steve J » Tue Jan 19, 2021 11:53 am
No, that's not the tab washer for the crank - it's the tab washer for the engine pivot bolt! Similar shapes, but different dimensions.
Steve J
Postby jbcollier » Tue Jan 19, 2021 3:08 pm
My engine pivot bolt has a spring washer.
jbcollier
Postby Big Al » Wed Jan 20, 2021 2:58 pm
Hi John and Steve.
I had no obvious washer to use with the pivot bolt and nut when I went to put the bolt back in.
The Lambretta Serviceman's Book First Edition shows it as a tab washer in the photo on Page 41, but my official parts book says it is a spring washer. I bought a spring washer, but there was not enough thread showing to use it with the nut!
That makes me think that the tab washer must have come from the pivot bolt, as I'm not missing a tab washer from anywhere else. I will see if it fits.
Thanks to both of you.
Big Al
Postby Big Al » Sat Jan 23, 2021 9:09 am
I tried the washer on the engine pivot bolt, but it was too small to fit onto the bolt.
Big Al
Postby Big Al » Tue Feb 16, 2021 7:38 pm
Hi Steve
You were right about the tab washer for the engine pivot bolt, but mine was clearly the wrong size.
I have now ordered the correct one (Casa Lambretta 266, Orig Part No. 07110152).
Many thanks, Alan.
Big Al
Return to Pre 57
Users browsing this forum: Google [Bot] and 27 guests
