Hi,
I am just wondering if anyone recommends to use fuel stabiliser on an LD150?
jbcollier wrote:No need for fuel stabilizer unless you want to store it with fuel in the tank and carb. If you ride it regularly, just fill, mix, and ride.
I live in a dry climate and store my scoots in a (mildly) heated garage. I store my scoots with the tank and carbs dry. If you live in a humid climate, the best thing is to move! Failing that, add stabilizer and fill the tank to the brim with the best fuel with the lowest ethanol content. Run it for a block or two so the stabilized fuel is in the carb as well. At least every year, completely drain and repeat the fill & running process.
Users browsing this forum: No registered users and 31 guests
