If you have any carb parts which you no longer require, and are willing to swap for others, including jets, slides, needles etc... please post the details here for other Forum members to see. Contact should be made using the Forum's PM system
by SimonC » Mon Jun 02, 2014 5:19 am
I have two VHST 28mm carbs, both with 300 float valves, a 40 and a 45 slide, various needles etc. looking to swap for one PHBH 26 or 30 mm. Reason for swap is that I want to use only the PHBH range on my scooters. The VHST carbs have done about 500 miles between them.
Simon
SimonC
by gp200ts1 » Sat Aug 09, 2014 8:34 am
did you find a swap or are you still looking for one. i have a 30mm phbh that i could probably jet to what you might need.
gp200ts1
Return to Carb - Swap Shop
