I've been a busy boy over the last few weeks, unfortunately it's been a case of one step forward and two steps back. sometimes three
Never, ever, EVER build an engine from bare cases. time and time again the build has stopped for a missing shim or washer.
I've decided to put this on the "wrong" side, hopefully if I need to get into the wiring I will have more room for my fat fingers to get in
The cases have come back from Oiltek, an absolutely fantastic
jobhttp://i456.photobucket.com/albums/q ... 4953346683A poorly scooter stops the build, and draws much needed funds.
All finished, back to the buid
The seat is back, very happy chap.
Twin tanks fitted.
Back to the engine,
The funds are very low so it's just a stage 4 200...... for now.
Engine in, missing washer and clip on the clutch arm means I can't fit the side casing.
forks in as well,
couldn't resist a quick trial fit.
This is where I had to admit defeat and seek professional help, as much as I tried I couldn't get the lights to work. I've fitted a bgm wassel ignition but couldn't find a decent DC ignition switch so under advice fitted a CASA AC switch. I just couldn't get the bugger to work so ended up taking it to NS Scooters to sort out. an hour later all the electrics are working as they should. isn't it
easy when you know what your doing lol.
Hours and hours spent on the garage floor is finally bringing some rewards.
So all the body work is fitted, the engine is in and running so it's now just to snagging items then hopefully I can get it MOT'd on Saturday, oh god there I go again setting deadlines
Fingers crossed for the next 5 days...and nights.
