by Meds » Fri Jun 06, 2014 9:07 pm
I got this idea from a biker website and it's the same principle we use when chemical cleaning boiler tubes at work.
I used some big round steel balls (like steel marbles from a kids building kit) to remove the worst of the rust, then used a 2% acid soak overnight, filtered checked and re soaked.
The acid mix is made up from bottles of vinegar and water, filtered it through an old white cotton shirt sleeve tucked inside a plastic funnel then kept re soaking and filtering until the acid came out clear. ( it took me about 4 days but mine was bad enough to block the petrol tap)
Clean the acid off with plenty of running water and dry it out ( I waited till the wife was out and stuck it in the fan oven for a couple of hours on a low heat.)
I used asda clear vinegar and a old white cotton shirt sleeve and drained it back into a clear bottle, this helps it to identify when the acid is running clear and how much crud is coming out.
It worked for me
