Fast n Furious wrote:Pilot jet then throttle slide. Throttle slide controls the mix up to about 1/4 throttle.
Check that you have the correct slide and pilot jet.
Check that the slide and carb housing are not worn.
Try a borrowed carb and see what difference that makes.
