Warkton Tornado No.1 wrote:According to the Dell'Orto carburettor technical document that describes most of their current range, the anti surge washer is important.
They would say that, though, wouldn't they? Having designed it for that range of carburettors.
The document is available as a pdf & well worth a read. For example, there's mention of slide profiles & the best shapes for two strokes to avoid turbulence in the venturi.
bolzenanker wrote:You've lost it, haven't you Andy.
Andy B.L.C. wrote:bolzenanker wrote:You've lost it, haven't you Andy.
On my own carbs I do however get all OCD & make sure 1 of the holes is directly over the idle jet mind...
Warkton Tornado No.1 wrote:These links are very good IMO
Users browsing this forum: No registered users and 23 guests
