26mm phbh on a reed valve 225 jetting advice
Postby camel » Thu Dec 25, 2014 6:28 pm
Hi,I'm scaling down the carb on a home tune reed valve mugello 225 from a 30 to a 26..has anybody got any 26mm carb set ups on a 225 reed valve motor they can share with me,weather its a rt,rapido,GT,ts1 dosn't matter at this stage
Cheers in advance
Camel
camel
Re: 26mm phbh on a reed valve 225 jetting advice
Postby hullygully » Wed Jan 14, 2015 2:14 pm
the info I have is:- slide 45 / needle X2 / atomiser AV268 / pilot 50 / starter 50 / main jet - 110 (big bore) 120 (expansion pipe),
non of the above is with a reed block, but as with every carb you should do plug chops anyway as even similar engines can be different.
hope this info gets you close
Return to Carburettors
Users browsing this forum: No registered users and 15 guests
