by St George » Sat Jul 26, 2014 4:11 pm
Remove carb place it on clean rag. First check filter, remove ALL jets and mixture screw ( count the turns ). Blast the carb with Carplan carb cleaner. The filter has probably down it's job. Remove tank and do it properly or you will get the same problem in the carb. Clean the tap as well. Put it all back after every hole is cleaned out with an air line if you can obtain one. I use a small plastic pipe and lungs. Good luck.
Colin
