by Adam_Winstone » Sun May 14, 2017 1:51 pm
Don't hold me to it, as I've not used a Casa top end and you need to be responsible for correct testing to ensure that all is well, however, I've always found that the 5589-2 (200 and 175) standard atomiser is too rich too soon an most tuned barrels that need to run a larger main jet. I've changed atomisers to allow the bike to run cleaner through the mid range so that they can cope with the increase coming from the main at 3/4+. Typically for a SIL Factory IV 200 or similar spec 225 I've ended up using a 5899-4 (GP150 atomiser) with a 125-135 main, the main being heavily influenced by level of modification of airbox (range of standard with standard filter, baffle out with standard filter, etc.) and specification of clubman and ability to rev. Do note that this combo has always been used with a good quality and clean standard type filter and a GP spec airscoop and standard seat. Many of the slope back seats will greatly restrict flow to the scoop.
45 pilot (Dellorto) is typical as the 48 and 50 typically are too rich low down.
Remember.... try it and test it thoroughly as it is down to you to ensure that ANY/ALL jetting is appropriate to your engine, rather than simply relying on the suggestions of other.
Good luck with it.
Adam
