gp200ts1 wrote:Well partly fitted. Not plug and play as it needed fettling. Clutch bush is a couple of thou bigger so the case needed dremmling, and the pinion teeth needed needle filing to allow it to mesh smoothly.
Other than that it was straightforward, just needs fitting to the scoot now.
Rich Oswald wrote:gp200ts1 wrote:Well partly fitted. Not plug and play as it needed fettling. Clutch bush is a couple of thou bigger so the case needed dremmling, and the pinion teeth needed needle filing to allow it to mesh smoothly.
I can confirm that the UNI sidecase needs slight dremmeling too.
ULC Soulagent wrote:Rich Oswald wrote:gp200ts1 wrote:Well partly fitted. Not plug and play as it needed fettling. Clutch bush is a couple of thou bigger so the case needed dremmling, and the pinion teeth needed needle filing to allow it to mesh smoothly.
The lambretta curse strikes again. Find it strange that in this day of age that manufactures still can’t get it right and fettle free. I’ll still be getting one though
Andy B.L.C. wrote:Just surprised that it took so long for someone to make a minor bit of engineering affordable...
3 x will be on order, the white finger (from chainsawing, brushcutters & Lambrettas) aint going away.... anything to keep us on the road eh...
Norrie Bodge wrote:Just acquired one of these kits
How are they for clearance with a wide rear rim and a 100/90 tyre fitted?
gp200ts1 wrote:Norrie Bodge wrote:Just acquired one of these kits
They will probably be tight, fitted mine with a 350-10 sip performer and it was fiddly. Can’t say the set up has made a huge difference as it is only slightly easier than it was before but it has made a difference. Appears to have been worth it. A road trip will be the proof of the pudding.
gp200ts1 wrote:Af race.
Fast n Furious wrote:I might struggle with my 10/120 rear tyre then eh?
watty-rugby wrote:My contribution. Fitted to a Lambretta sidecase. No issues, went straight in. Done while fitting a 5-speed box.
Users browsing this forum: No registered users and 17 guests
