Taffspeed stainless steel u- pipe
Postby johnnyjarvis » Sun Feb 18, 2024 1:09 pm
I seen these someone had made these recently.
Anyone know who had made them ?
Cheers, Will
johnnyjarvis
Re: Taffspeed stainless steel u- pipe
Postby gaz_powell » Sun Feb 18, 2024 1:31 pm
I would have one them!
Postby ste s one » Mon Apr 15, 2024 10:55 am
Just wanted to resurrect this thread in case anyone had an update ion the Taffspeed headers ?
ste s one
Postby gaz_powell » Mon Apr 15, 2024 1:52 pm
As soon as i have time i intend to see how close the SSC taffy pipe u bend is to the original.
Ive got a gen taffspeed and a few SSC ones.
Postby ste s one » Mon Apr 15, 2024 2:54 pm
Hi Gaz ,
I have an SSC copy lying around somewhere , and from memory they are significantly different . I know that the fitting into the stub is quite a bit smaller diameter for a start .
ste s one
Postby Dazts1 » Tue Apr 16, 2024 8:38 pm
The taff u pipe fits over the expansion body where the Saigon copy slips inside the expansion body. Plus as you said the Saigon version is probably close to 42mm ( the version I’ve seen is ) where the taff is probably closer to 48mm.
Postby Dazts1 » Tue Apr 16, 2024 8:39 pm
If someone is knocking the u pipes up I’d be intrested.
Postby gaz_powell » Tue Apr 16, 2024 9:09 pm
Early SSC were 42mm but they went to 48mm. Thwy have had a few changes.
Yes knew the joints were different just wondered if the bend was in the ball park.
Ive also got a 48mm u bend (unknown) that is just the tube with no ends, think it could be just a 48mm AF clubman, will see if thats anywhere near..... When i have some time!
Users browsing this forum: No registered users and 3 guests
