AF double row hub bearing help required
Postby Bidsy » Fri Jun 28, 2019 11:11 pm
Just got one of the new AF double row hub bearing to go with my AF clo5e, I notice the bearing has a seal in both ends, do you need to remove the internal one to allow the bearing to be lubricated.
Can’t seem to get through to AF Rayspeed to ask them.
Bidsy
Re: AF double row hub bearing help required
Postby Fast n Furious » Sat Jun 29, 2019 12:18 am
This bearing has a double Labryinthe seal. No need to mess with it.
Just make sure that your gearbox breather plug is free breathing.
Postby Knowledge » Sat Jun 29, 2019 3:11 am
I have run one for a short period with both seals intact, and it has been fine.
Much less friction than the usual garter seal.
Postby gunnerdaz » Fri Aug 02, 2019 10:13 pm
I've just bought one of these. So no lubrication needed.
gunnerdaz
Postby Knowledge » Sat Aug 03, 2019 10:11 pm
Correct. Keep both seals in place.
Users browsing this forum: Google [Bot] and 26 guests
