paul213 wrote:have used solid copper exh gaskets since the 80s . i just heat them to cherry red and quench in water to anneal each time its removed ,refit with high temp exh sealant . biggest advantage in my opinion is they dont compress over time so your exh stays tight .still got the one i purchased from taffspeed in 85 with my stg 4.
shamrockexpress wrote:Does anybody go gasketless?????is it possible to used a good enough exhaust paste?????
ULC Soulagent wrote:shamrockexpress wrote:Does anybody go gasketless?????is it possible to used a good enough exhaust paste?????
It be a brave man or woman to do that Damian
nsaints wrote:7 - assemble using new k-nuts
I use K-nuts instead of the usual lambretta brass nuts. Find them on eBay or Merlin Motorsport
Fast n Furious wrote:shamrockexpress wrote:Does anybody go gasketless?????is it possible to used a good enough exhaust paste?????
If you do this you may find that the exhaust box doesn't line up nicely with the brackets fixing points because the manifold is now sitting about 3mm higher!
shamrockexpress wrote:Fast n Furious wrote:shamrockexpress wrote:Does anybody go gasketless?????is it possible to used a good enough exhaust paste?????
I went with the solid copper gasket and three bond on the ex-box, will see how it holds out when the weather eases off
Users browsing this forum: No registered users and 23 guests
