Digital Speedo’s
Digital Speedo’s
Postby Bilko » Fri Dec 09, 2022 8:13 pm
The sensor on my Vapor Tailtech has packed in and apparently no longer available, so I’m now looking for a new Speedo.
I’ve had SIP (two that never worked properly).GPS strap on types. Scootronics (had to be sent back a few times).
I’m after something like the trail tech that has an odometer and trip meter etc. is there anything out there that people are using?
Bilko
Re: Digital Speedo’s
Postby tim_mason » Fri Dec 09, 2022 9:46 pm
I may have a new sensor for a Trailtech if you want to keep the unit,
tim_mason
Postby Bilko » Sat Dec 10, 2022 12:45 am
tim_mason wrote:I may have a new sensor for a Trailtech if you want to keep the unit,
This is the part I want, the sensor to the connector. If you have a spare, I’ll gladly buy it from you.
Bilko
Postby tim_mason » Sat Dec 10, 2022 3:57 pm
Hello, i have a speedo sensor with a MB bracker and a temperature sensor plus new magnets , £25.00 posted
tim_mason
Postby Bilko » Sat Dec 10, 2022 5:40 pm
tim_mason wrote:Hello, i have a speedo sensor with a MB bracker and a temperature sensor plus new magnets , £25.00 posted
PM sent, thanks.
Bilko
Postby Micky67keane » Fri Sep 08, 2023 10:44 pm
I bought a circular gps speedo for £50 off ebay,split a standard speedo,made a plastic blanking plate to cover the circle of the speedo(leaving an opening to see the speedo reading).It has a small gps antenna(24mm x 15mm)
For £55 I now have a gps digital speedo with odometer.
If I knew how to upload pics I would but looks very presentable and works a treat.
Micky67keane
