60x110 GBM crank fit into Uni casing
Postby jdevane5 » Tue Apr 25, 2023 7:27 pm
I'm just about to fit a nice new BGM 60X110 crank into a 200 new Uni casing and Uni Mag flange.
What the is typical gap I should be aiming for crank to Mag flange?
I was going to aim at 1mm? -Just bought s selection of mag flange gaskets but conscious there is not much usually much play with the mag flange studs and nut / washer fitment.
Any pointers welcome -Cheers
jdevane5
Re: 60x110 GBM crank fit into Uni casing
Postby hullygully » Wed Apr 26, 2023 8:47 am
have you got Sticky's manual? all the info's in there bud
Broady also sells 0.25mm, 0.5mm & 1mm thk (I believe) shims to go between the crank & the drive side bearing 8-)
Postby jdevane5 » Thu Apr 27, 2023 10:18 am
Yes got Stickys, somehow missed the info...but just found it though .6 to 1mm gap between crank and Mag.
I'm at .4mm -Bit tight so new Mag flange thicker gasket ordered... :D
jdevane5
