It can be what you want it to be its a mini ts1 with a 28ml dellorto and a clubman will pull tv175 sx 200 gearing and a 16 tooth front with a jl or devtour leave with a 15 tooth front
Built one for one of our lot, as Andy says mini TS , 30mm delly , jl3 pipe li150 Spanish box (Graham's choice) 46x16 ok on flat struggled up hills (up and down box ) better with Italian LI , 5 plate clutch , mec crank , little monster
The kit is designed to rev high, don't spoil it by trying to turn it into a tourer. Short gearing and revvy exhaust works great. Mine ran 5.4 final drive, scootrs exhaust and TMX27 Mikuni. In a foolish attempt to turn it into a motorway tourer I dropped the gearing to 5.00 and fitted a JL3 and it became a plodder that spent half it's time in 3rd trying to get back into the power band.
