Hello,
My bro in law is running in a gp200 (Italian) fitted with a mugello 200 kit, Sito exhaust, it's running on a 28mm dellorto and a ram air filter with hose. Last week he conked out but after 5 minutes it started again. Got 200 yards up the road and conked out again. So we took the hose and filter off the carb and it ran better. Got home which is about 8 mile.
I noticed the bike smoking a little more than expected but cleared on the way home, must admit he was running in at 40 mph at first, seemed to be boggy at 40 mph then increased to 50/55 mph which helped, is this a case of over jetting?
Haven't a clue what jets are in it and running an BS8ES plug, which seemed a little black?
The guy wants a filter or hose if poss as fuel seems to go on the runners, any better options that helps it breath and stops fuel on the panels, side panel is standard with no hole for carb.
What would you suggest?
Thanks for help in advance, lee
