Eden wrote:Scooterlam wrote:Vmakgp wrote:Afternoon chaps' I'm looking at matching my small block casing to my GT 186 kit I've marked out on cylinder gaskit face and at the minute the walls are around 7..5 to 8mm I've used the ally packer supplied wich is a decent match to the ports on the GT barrel but I'm reluctant to fully match them as it would take the casings down to 5 mill or just under, so do I not bother at all , or would it be worth maybe taking around 1.5 to 2mm out ? I'm fitting the new GT 60/110 stroke crank and there fore will be using a packer & was worried about taking the width of the gasket face down to much .
Any advise much appreciated .
Has anyone ever quantified the gains of matching case to barrel.
I dont and Im more than happy with the results.
yes and if you did you would be even happier than you currently are
I know but that would be the first step on the path towards perfection. A long journey to an unreachable destination.
I would also have to change my unmodded small block mag housing.
