Unread postby dscscotty » Tue Jan 10, 2017 6:10 pm
The GT kit i believe uses a Yamaha piston so the crown height as well as the dome height is different to the Asso
Warkton Tornado No.1 wrote:Unread postby dscscotty » Tue Jan 10, 2017 6:10 pm
You are quite correct & I apologize for missing the obvious!
I think the ('central') compression height is 36 mm as opposed to 39 mm...
Users browsing this forum: Adam_Winstone and 34 guests
