Feersum Injun wrote:Can't report results yet as I'm just nearing completion of my TS1 230 build but I've gone for 4.7 final drive. JL3 pipe with Li150 box, 60/110 crank. 47/17 gearing on this set up. Not sure if this helps but it's based on advice from a couple of very knowledgable chaps!
bike grim wrote:So thats about 4.8:1,
Depends on your style of riding. I ran at 4.45 on my TS1 230 ( moderate tune) and it was OK generally for touring etc unless you got a strong headwind or a long drag Hill then you would be chasing the revs a bit. I ran it at 4.12 on my 283 and it copes well enough although I could never get rid of huge rich spot at 4300-4500rpm which I don’t seem to have using a modified Gori
I’d give it a go with what you’ve got and see if you/it likes it. Won’t be that far off.
I’m currently experimenting with a CST3 on a TS1 and it’s a lot more torquey.
carlos fandango wrote:bike grim wrote:So thats about 4.8:1,
I had the same experience .....massive rich flat spot at 4500 and 5000 (TS230).......horrible ....got used to it in the end .......recently switches to a cst3 and its transformed the engine ....love it now, its currently 4.7 looking to lower that to 4.4/4.5 ish .
Storkfoot wrote:carlos fandango wrote:bike grim wrote:So thats about 4.8:1,
What was the effect on top end, Russ?
carlos fandango wrote: following peeps doing 50 was hell .....
foremanbob wrote:carlos fandango wrote: following peeps doing 50 was hell .....
Watch out for that on the CST3...with 4.4 final drive.... I found that riding with a group I could never get into 4th.... or was hunting between 3rd and 4th
coaster wrote:
You should try following a bog standard Rally 200 for a thousand miles round Germany, 2 stroke version of the Hare and the Tortoise
bike grim wrote:I’ve put my Supertourer back on the DSC Scotty TS1 to try it with the 5 speed box and messed with the jetting a bit and it’s riding really well. I honestly thought it would finally convince me to bin it off and was planning another experiment with a Gori but I’m leaving it for now. The 5 speeed box is set up at 4.8 in 4th and 4.3 in 5th. It’s easy to leave it in 4th if you are into a head wind or steep hill just to keep the revs up and cool the motor but it will actually pull 5th. PHBH 30, 138 main, 55 pilot, x13, 268 atmomiser, 40 slide. Riding up to Malton it was giving 10 miles per litre. The real test was coming back in the wind and it coped well enough.
The CST3 has been on my 283 since before the Euro and it’s staying on. I’ve got a 410 main (35 TMX) but still retuning 9 miles per litre. It pulls like a train but I’ve lost a bit of top end speed. Still does 80 easy enough and that’s fast enough LI150 box 19/46 (4.12)
